programming issue
Old Jul 12, 2017 | 07:44 AM
badjojo13's Avatar
badjojo13
Default programming issue
3 months ago a friend got is Diablosport I2 tuner andthrough him I got a programme license for my 2010 Ram, after many attempts atprograming my 2010 along with the help of the diablo tech we were never able toget in my PCM for programming, so eventually I sold the license to a friend witha 2011 ram and everything worked perfectly in his truck. Now I decided to getmy on programmer and got a bullydog GT programmer went through the install, onceon the saving file portion it got to 100% then error 224 came up (cam generalerror. Internal data processing error.) tried 3 times always the same. So ranthe diagnostique mode on the tuner and I get a DTC U1113 look up on theinternet some talk about a/c pressure problem but one site talk about PCM (http://www.engineobd2codes.com/u1113_dodge-ram.html)since I have never gotten a engine light on and I know it works I am really thinkingit’s the PCM
ANY IDEAS ???
Old Jul 12, 2017 | 08:11 AM
Moved to the correct section.
Have you called tech support?
Old Jul 12, 2017 | 08:41 AM
badjojo13's Avatar
badjojo13
Diablo teck was not able to help me.
bullydog I am waiting for them to answer my email and I will try to called them in an hours when they are open.
Old Jul 12, 2017 | 09:26 AM
Probably your best bet.
Old Aug 4, 2017 | 01:51 PM
badjojo13's Avatar
badjojo13
bullydog offered great service the have fix my gt programmer.
now there are 3 option for program on the tuner
stock
regular
premium
witch one is the best to used what are the differences
note : my truck is a 2010 RAM SLT Crew cab 4X4 with a 5.7Hemi and 3.55gear only mods are front daystar 2.5'' leveling that really only give 2'' and tires are BF KO" 285/65/20
thanks you
Old Aug 4, 2017 | 02:32 PM
Depends on what you want to spend on gas. "stock" is exactly that. Stock. Regular is an improved tune, designed to run on regular gas. Premium is a more aggressive tune that requires premium fuel.
