Bad sway
Old Sep 2, 2017 | 08:22 PM
Jimmy K Crain Jr's Avatar
Jimmy K Crain Jr
Default Bad sway
I have a 2010 dodge ram 1500 with the 4.7l motor. When I have a heavy load in the back the truck sways a lot after hitting a bump. It just rocks left and right. I have replaced the front struts, rear shocks, and rear springs. After doing that it has gotten better but it's still pretty bad. Any help would be appreciated.
Old Sep 2, 2017 | 10:25 PM
How much weight? Are you simply putting too much in the wrong spot, and unloading the front wheels?
Old Sep 2, 2017 | 10:55 PM
Jimmy K Crain Jr
No it's not that much weight. I'm not hailing rock or anything it's camping/fishing gear for the family and i.
Old Sep 3, 2017 | 10:03 AM
Ok, that shouldn't be able to overload the truck......
What do you mean by "sway"? Does the truck bounce around? Or does it simply not want to go in a straight line?
Old Sep 3, 2017 | 11:47 AM
Jimmy K Crain Jr
The truck rocks left to right like a seesaw.
Old Sep 3, 2017 | 02:03 PM
That's just weird.......
How do the sway bar links look?
Old Sep 3, 2017 | 02:06 PM
Jimmy K Crain Jr
I can't see anything wrong with them no cracks in the rubber or anything. If I have someone stand on the back of the truck and jump on it I do get a little bit of a squeak out of the rear ones
Old Sep 3, 2017 | 03:25 PM
You have already gone after everything else I could think of....... I would have to ride in it, to speculate further.....
Old Sep 3, 2017 | 06:02 PM
primem's Avatar
primem
are you running big over sized tires... tires in general and tire aspect ratio has a huge effect of sway.
Old Sep 4, 2017 | 10:12 AM
Pressures too.
