2013 overheating
Old Oct 15, 2017 | 04:56 PM
Phil03's Avatar
Phil03
Default 2013 overheating
Temp spiked to 240-250 yesterday for less than 10 minutes. Found to be down a gallon of coolant. Oil looks and smells fine. Noticed brown goop in radiator cap. Assuming bad radiator. Likely my heads warped? Leaning towards no. Any thoughts?
Old Oct 15, 2017 | 08:09 PM
Flush the cooling system, thoroughly..... Twice. Check the system for leaks. That coolant had to go somewhere. Likely the brown goop was 'stop leak', from some previous attempt at a repair.
Old Oct 17, 2017 | 06:06 PM
200amp's Avatar
200amp
check the raditor cap ,mine was bad on a 09
