Air intake temp sensor
Old Jan 29, 2018 | 01:19 AM
KConley's Avatar
KConley
Default Air intake temp sensor
Code reading said faulty air intake temp sensor. I put a new sensor on and I'm still getting the same code reading. What's going on?
Old Jan 29, 2018 | 08:00 AM
SHO Rod's Avatar
SHO Rod
Welcome to the forum!
What is the year and model of the Ram you are working on? Also, which engine does it have and what is the particular diagnostic code that is being set?
Keep in mind that diagnostic codes only report what sensors/systems are out of range and hence there are often more than one code related to a sensor/system. Rarely will a diagnostic code be so detailed that it states exactly what part to replace. That's why they are called "diagnostic" codes. Usually some diagnostics are required.
-Rod
