No codes stalling
Old Mar 12, 2018 | 03:25 PM
Nathan Brownell's Avatar
Nathan Brownell
Default No codes stalling
Hi guys new to the forum and just trying to get some answers. Little background on my truck 181,xxx miles 09 1500 33x12's no lift. Replaced the tranny about 20,xxx miles ago. No motor work other than basic maintenance. My truck is stalling everytime I come to a stop at a stop light. Almost as if the truck wants to surge forward at the same time. Idles fine. Drives fine. No vibration from the motor when idling from misfire or anything like that. Fires right back up after put in park like nothing happened. Im getting no codes on a scan tool. What's going on? Torque converter? Plugs/wires? Fuel pump? Thanks for any input.
Old Apr 28, 2018 | 12:27 PM
David Hallisey's Avatar
David Hallisey
Have you figured out the problem?
Old Apr 28, 2018 | 01:37 PM
Nathan Brownell
I have not figured out the problem. I have replaced the throttle body, replaced plugs, replaced pcv valve, and have had the pcm updated at the dealer with no luck.
Old Apr 28, 2018 | 04:33 PM
sottis's Avatar
sottis
Seems like there was a tech bulletin about this regarding the torque converter.
