Remote Start Install???
Old Apr 13, 2018 | 09:38 AM
darleyhavidson's Avatar
darleyhavidson
Question Remote Start Install???
Ok, the used 2013 RAM 1500 I recently purchased does not have remote start (unlike what I was led to believe). In any advent, what is the best way to install a remote starter? My truck has the tip key start fob. Any advice and practical experience would be appreciated.
dh
Old Apr 13, 2018 | 10:45 AM
Dealer or professional installer.
Old Apr 13, 2018 | 01:03 PM
darleyhavidson
I am looking for a DIY approach. I know there are modules you can install that work with the existing key fob. Just looking for someone to provide feedback based on their experience.
dh
Old Apr 17, 2018 | 07:43 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
idk how well it works but if you google dball (i think) they sell a plug in module to work with the factory key for remote start (among other things)
Old Apr 27, 2018 | 03:41 AM
Reject's Avatar
Reject
I used Fortin's Evo-All in my work Caravan worked great easy to install. But with the Rams there is more to it and some splicing now. Then Caravan was Plug-in and program a fob and done.
Remote start was Lock x3.
They also have a newer Model the Evo-One.
Looking at the Evo-All install (Same for Evo-One), Realistically you only need to tie 3 wires in.
Can High, Can Low (Both on OBDII Port) and Ignition + (By ignition module). Then plug in the T-harness (part THAR-CHR6) with the Ignition module (where your key slots in to start the truck)
Normal install is 5 wires, Door Switches for safety so wont start if Doors open, and Parking Lights I assume to tell you its running.
Ram 1500 2013 Page
http://fortin.ca/en/vehicles/ram/150...-standard-key/
Personally ive looked at this, Since I have the Fortin Evo-All from the caravan, but dont want to void any warranty on my 2015, Plus factory comes with 2 more fobs which is over 2/3 the cost of the factory remote start + install anyways.
Old May 1, 2018 | 03:58 PM
xsparta11x's Avatar
xsparta11x
dh
DBALL with T-Harness, that's it. No Spliccing or soldering required, just plug and play after configuration on computer (not hard at all, just call the seller, and he tells what buttons to press takes 5 mins). I have had this setup on my 2010 for the past 6 years. I just walked my dad over the phone on how to do it. (he is not mechanically inclined at all) took 30 mins. you press the lock button 3 times and it starts, another 3 times and it turns back off. Linked below. any questions let me know.
DBALL remote start kit for Dodge Ram 2009-2017
