Rear diff fluid change
Old Apr 26, 2018 | 10:44 PM
JD Spears's Avatar
JD Spears
Default Rear diff fluid change
Evening gentlemen.
this is probably an easy fix but certainly has me stumped.
2012 bighorn, level shop floor, drained exactly 3 quarts rear diff but took only 2 quarts before coming out of fill hole. Clearly there is an issue but what? I drove to work next day.
( only 4 miles) that evening after shift, pulled around to shop and pulled fill hole plug. Fluid POURED out. What in Dodge hell is going on I ask???
thanks..
Old Apr 27, 2018 | 08:27 AM
Moved to the correct section.
Old Apr 27, 2018 | 11:02 AM
JD Spears's Avatar
JD Spears
My apologies, though this was the non tec board.
Old Apr 27, 2018 | 11:09 AM
Seems like a tech question to me.....
Old Apr 28, 2018 | 10:27 PM
Chainlink's Avatar
Chainlink
Any thoughts?
Old Apr 29, 2018 | 09:21 AM
SHO Rod's Avatar
SHO Rod
Hmmm, about the only thing I can think of is to check the differential vent tube to make sure it is not plugged or kinked.
-Rod
