Electrical Problems!
Old Apr 27, 2018 | 11:17 AM
Qweasy's Avatar
Qweasy
Default Electrical Problems!
2015 Ram 1500
cruise control doesn't work
gear +/- on steering wheel doesn't work
driver's side window does not go up or down
gas cap light is permanently on
A/C clutch will not engage
I have checked all the fuses under the hood.
The truck only has around 35k miles...
Does anyone have wiring diagrams and pin outs of the wiring related to these problems?
Old Apr 27, 2018 | 11:19 AM
Qweasy's Avatar
Qweasy
2015 Ram 1500
Old Apr 27, 2018 | 12:18 PM
You should still be under warranty.....
Old Apr 27, 2018 | 02:23 PM
Qweasy's Avatar
Qweasy
Its a rebuilt from salvage, so no warranty. Wiring diagrams and pin outs would be helpful
Old Apr 27, 2018 | 02:27 PM
SHO Rod's Avatar
SHO Rod
FCA is pretty tight with wiring diagram information. What is available is not real detailed, but you can access at least most of what you are looking for at this site.. Be sure to select "Wiring Diagrams" before entering the vehicle information.
Most of the issues you listed above could easily be unrelated to one another so checking the diagrams for a common link is a good idea if you won't feel like having the dealer dig around for several days trying to make sense of the issue(s).
-Rod
