Led canibus antiflicker
Old May 10, 2018 | 05:47 AM
Kdog4069's Avatar
Kdog4069
Default Led canibus antiflicker
first time Member First Time first time Member First Time Post.. can anyone help me? I just bought a 2018 Ram 1500 and I would like to buy aftermarket Leds. I keep coming across I need a anti flicker canibus... can anybody suggest are good canvas anti flicker for my truck.? Thank you.
Old May 10, 2018 | 07:33 AM
Which bulbs do you want to replace with LED's? That information would be helpful.
Old May 10, 2018 | 10:01 AM
Kdog4069's Avatar
Kdog4069
Sorry about that... 9005 low beam
Old May 10, 2018 | 01:12 PM
SHO Rod's Avatar
SHO Rod
Yep, you'll need the anti-flicker box with the LED bulbs. I converted my 2014 Ram 1500 Laramie Limited high and low beams to LED and without you'll get a constant warning while the lights are on that the bulbs are out. The anti-flicker is not directly related to CAN bus as far as I know, but often is contained wtihin the same module.
I'm not sure if the 2018 uses LEDs for all the turn signal and side marker lights. If not and you opt to upgrade any of those to LED, you'll need ones that are either compatible with CAN or you'll need to add load resistors to keep the bulb out indicator system happy.
-Rod
Old May 11, 2018 | 05:16 AM
Kdog4069's Avatar
Kdog4069
Rod,
Thank you so much. I appreciate all the help everybody is giving me thank you again and I will look for these parts for my truck. By the way I have 2018 Laramie.
Kdog
