2014 Ram diagnostics access
Old May 25, 2018 | 01:13 AM
limechallenger's Avatar
limechallenger
Default 2014 Ram diagnostics access
I got a 2014 Ram regular cab 4x4 ,5.7 hemi. 35000 miles. came out after work to fire up the truck and have a check engine light on! is there any way to retrieve the diagnostic code without plugging in a OBD reader?
Thanks Limechallenger
Old May 25, 2018 | 08:06 AM
SHO Rod's Avatar
SHO Rod
Did the Ram start, or is it stranded? If it starts fine you could drive to a local auto parts store (assuming there is one near you) and they can pull generic OBD-II codes at no charge.
Chrysler used to have a means of displaying diagnostic codes via a sequence of turning the ignition key on and off, but I'm not sure they still do that. It would be more difficult with the push button start as well.
-Rod
Old May 25, 2018 | 10:20 AM
limechallenger
Yes the truck started and seems to be running fine,I just was looking for a way to check codes myself.
Old May 25, 2018 | 06:47 PM
oldjeep's Avatar
oldjeep
A Bluetooth code reader that talks to a phone app is about $20.
Old May 26, 2018 | 04:47 PM
limechallenger
Nice, thats a good idea! I'll check into it!
