2014 Ram 2500 Spare
FWIW, the smallest wheel size offered in 2014 for the 2500's was an 18. However, I don't think you'd have to worry about brake caliper clearances with a 17" wheel, since the 3500's had a 17" wheel option and (I believe) used the same diameter rotors.
If you've got the 20" wheels on your truck now, you probably have a 285/60R20, and the best match in a 17" wheel would be a 295/70R17, but options will probably be fairly limited since it's not a real popular size.
You might have better luck sourcing a used 18" wheel and putting a 275/70R18 on it, since they're both much more common.
$.02
$.02
