Cylinder #5misfire 2011ram bighorn
Old Jul 8, 2018 | 05:29 PM
Jamie Smith's Avatar
Jamie Smith
Default Cylinder #5misfire 2011ram bighorn
Hey there I'm new and look for some help from fellow dodge owners. I changed the plugs and the motor still isn't shifting to ECO when you steady the throttle or let off the gas. Engine light is still on. Any help is appreciated. Names Jamie
Old Jul 9, 2018 | 01:24 PM
Mike Sal's Avatar
Mike Sal
Take it to Autozone & have them run the codes.....if it'a "030x misfire".....it may be a bad lifter / cam....
Old Jul 9, 2018 | 03:22 PM
SHO Rod's Avatar
SHO Rod
Does it run like it has a misfire? Is the engine clattering/tapping or just idling roughly? If you pull the plugs for cylinder #5 do they appear damp like one that is getting fuel but not spark or do they not appear to be getting fuel? Have you tried a compression or cylinder leakdown test?
-Rod
Old Jul 10, 2018 | 06:10 PM
oldjeep's Avatar
oldjeep
Try swapping the coil pack from the troubled cylinder to another and see if the code follows.
Old Jul 10, 2018 | 11:44 PM
Mike Sal's Avatar
Mike Sal
I've read dozens of reports from owners who have this problem and the number one thing they are always told while trouble shooting is to change plugs and swap coil packs....not one single time has that been successfull in all the reports I've found....it always turns out to be a bum lifter that takes the cam out. Somebody on the Dodge Ram Owners FB page has started a poll to try to get an estimate of just how many others have had this problem.
Old Jul 11, 2018 | 07:53 AM
SHO Rod's Avatar
SHO Rod
That may be, but it sure is a lot easier to check and much quicker to possibly rule out than a lifter/cam problem. It's still worth the small amount of time to check.
-Rod
