09 trx4 rear end
Old Jul 17, 2018 | 02:53 PM
shaner13's Avatar
shaner13
Default 09 trx4 rear end
hello i am trying to figured out exactly what parts i would need to rebuild the rear end in my 09 trx4 ram
Old Jul 17, 2018 | 03:57 PM
What happened to it?
Old Jul 18, 2018 | 07:18 AM
shaner13's Avatar
shaner13
Broke spines off the ring and pinion, spider gear. Just figure to rebuild the whole thing
Old Jul 18, 2018 | 07:55 AM
New gears, new spiders, a rebuild kit for the posi, if you have one, and a 'master install kit' for the gears. I would replace axle bearings as well. Several quarts of the correct fluid.
Ever done gears before? Its a pretty exact science.... need a selection of special tools.....
Old Jul 20, 2018 | 12:47 PM
daktwos's Avatar
daktwos
Also consider sourcing a good used rear end in the gear ratio you need from a local salvage yard then hang a new set of brake pads and change out the differential fluid if you don't have the skills to set up a rear end.
Old Jul 20, 2018 | 04:03 PM
Most of the time, this ends up being the cheaper option as well. Paying someone to do the work gets expensive in a hurry. (as gear setup is a time consuming affair.)
