Speed limiter 2016 RAM 2500
Old Aug 8, 2018 | 04:39 PM
simocummins's Avatar
simocummins
Default Speed limiter 2016 RAM 2500
Is there any way to adjust speed limiter on my 2016 RAM (Cummins).
I should have my truck Limited to 54-55 mph.
Simo Mäkinen/Finland
Old Aug 8, 2018 | 04:47 PM
Do you have a heavy foot?
Programming is the only way to do it. The dealer *might* be able to.... but, likely you will need to have someone in the aftermarket deal with it.
Old Aug 9, 2018 | 09:08 PM
WvChamp's Avatar
WvChamp
Keep autographing the Man in Blue's book and He'll limit you.
Old Aug 10, 2018 | 12:09 AM
primem's Avatar
primem
aftermarket tune only. If you need a major engine component for warranty...they will check the programming. If its tuned your warranty is void. They can tell how many times the pcm has been flashed so there is no hiding a tuner.
