Problem with power outlet
Old Aug 16, 2018 | 10:49 PM
Motorcycle girl's Avatar
Motorcycle girl
Default Problem with power outlet
Hello all, my power outlet is not working anymore. It also feels kinda loose.
any suggestion please? 2012 ram 1500
Last edited by Motorcycle girl; Aug 17, 2018 at 12:44 AM. Reason: Forgot model in subject
Old Aug 17, 2018 | 05:11 AM
primem's Avatar
primem
if the fuse is ok, check for power and grd at the connector. a special tool is required to remove the receptacle; without the tool, access the connector by removing the trim pieces. if you have power and grd at the connector...replace the receptacle.
Old Aug 18, 2018 | 06:13 PM
Motorcycle girl
Thank you
