4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have an 09 ram 1500 and my fog lamps won't work. They have new bulbs and I have no idea which fuse or relay it is to check. The switch works fine but no lights!
If you have the owner's manual there should be a fuse diagram and circuit description table in there. If you don't have a manual you should consider downloading one.
