4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Is there anyone that has fuse panel layout diagram for 2018 Ram 2500? Tried taking a picture of the inside cover of fuse box, but it doesn’t come out clear and fuse numbers are illegible. Any help would be much appreciated. Thanks
All I can find online is the pdf version of the owners manual, not really helpful.
If you have the cover, and the legend is inside the cover, why do you need a pic?
t’s very hard to read, especially at night when you’re trying to count fuses to make sure you get the right one while holding a light to see the cover where the diagram is and also holding the cover open. It took two of us and even more difficult the way the fuses are randomly placed.
Just thought there may be a diagram of how the fuses are numbered somewhere on the World Wide Web.
I will try to take another/better picture of the cover so I can put it with the little bitty part of the written owners manual they do provide. At least it has the fuses listed and what they control. Also, hard to distinguish some of the numbers like 6 from 8’s and 9’s from 0’s they are very similar.
Thanks for response and I’ll try to stop being such a girl. LOL
That sounds suspiciously sexist.
Maybe try a better camera? Something with higher resolution?
