Intermittent chime
Old Jan 9, 2019 | 06:03 PM
Skanaziz's Avatar
Skanaziz
Default Intermittent chime
2011 dodge ram 5.7 hemi Chimes intermittently every time I drive it, CEL blink on and then right back off. If you aren't looking at the gauges you don't notice it flash, rpms fluctuate up to a couple hundred rpms. CEL does not stay on or throw a code for obd II reader. The chime is driving me crazy!
Old Jan 9, 2019 | 06:27 PM
The chime is likely because of the CEL coming on. Now, WHY it's coming on becomes the question. Given the RPM bounce though, I would suspect the TPPS...... maybe.....
Old Jan 9, 2019 | 08:17 PM
Skanaziz's Avatar
Skanaziz
I wish the CEL would just come on and throw a code!
Old Jan 10, 2019 | 06:44 PM
SHO Rod's Avatar
SHO Rod
If the CEL blinks due to a diagnostic event, even if it's not staying on, there should be a diagnostic code. Does your code reader only read current codes or will it also read historical and pending diagnostic codes?
Another thing to check is to make sure your battery cables are clean and tight. Maybe the chime, RPM stumble, and blink are happening due to a momentary power loss?
-Rod
Old Jan 10, 2019 | 09:17 PM
Skanaziz's Avatar
Skanaziz
Current and historical codes not pending codes. I will check the battery cables!
Old Jan 12, 2019 | 01:19 AM
Black Opal's Avatar
Black Opal
Cables were my suggestion, also just a loose, broken or breaking wire. But actually sounds like a sensor, no? oxygen maybe? emissions? gl
peace
