Dome Lights on a 2015 RAM 2500
Old Feb 21, 2019 | 03:02 PM
jimmymjr's Avatar
jimmymjr
Default Dome Lights on a 2015 RAM 2500
I'm having an issue with the dome lights not coming on when any of the doors are open. The door switches are working, when you open them it shows up on the door open display. When you rotate the switch they do not come on. The map lights come on when you press them but not by the headlight switch or the doors. The fuse is good, the bulb is good, and what I can see of the wiring it looks good, not hard or brittle or anything. I have the uconnect 5.0, I cant find an option to change or turn it on in the setup menu. Some one told me they thought it might have been put in "black out mode". Is that a possibility? if so how do I fix it?
Old Feb 21, 2019 | 05:06 PM
TrueDogman's Avatar
TrueDogman
On My 03 and 12 i can turn off the interior lights by moving the dash dimmer switch all the way off. Does yours have this ?
Old Feb 21, 2019 | 05:07 PM
TrueDogman's Avatar
TrueDogman
Sorry. Just read your post again and seen you already tried that.
Old Feb 21, 2019 | 05:45 PM
SHO Rod's Avatar
SHO Rod
Aren't the map lights different from the courtesy lights that illuminate when the door is open? Or am I getting the Ram confused with my car?
-Rod
Old Feb 23, 2019 | 08:11 AM
jimmymjr's Avatar
jimmymjr
I’m not sure about that my last Dodge was an 1996. I just replaced it with the 2015. The map and dome both came on with the doors and switch.
