How to set proper tire pressure
Old Apr 9, 2019 | 09:33 AM
polymolybadchit's Avatar
polymolybadchit
Default How to set proper tire pressure
I seem to keep chasing proper tire pressure. And first I have a quality digital pressure gauge that I use to compare with my trucks tire pressure display. (2018 RAM 2500 4X4 Longhorn) and it matches.
The drivers door sticker for my trucks tire size and payload recommends #65 front and #80 rear 'COLD"
My question is what is considered cold? And what should the proper tire pressures be with normal driving temperatures? I once set my cold pressures (@55f) as recommend BUT at normal driving temp (@80f) my pressures grew to 79 front and 94 rear. this seemed quite high to me and since I was towing a 12K pound trailer I was concerned my rears were over pressured.
What should the tire pressures be when operating at normal daytime driving temps?
thanks!
Old Apr 9, 2019 | 10:20 AM
The tires will heat up under use. They will heat up more under heavy use. That's normal. If you set your tire pressures 'cold', (I.E. having driven less than 5 miles) you are all set. Folks EXPECT pressures to rise while driving, and the cold pressure takes that into account.
Old Apr 9, 2019 | 09:27 PM
primem's Avatar
primem
and if you have tpm sensors...in winter, set the pressures to 2 psi over the placard recommendation. this will prevent the tpm light coming on due to temps drops overnight.
