4 inch VS 6 inch lift...
Old Jun 4, 2019 | 01:17 AM
Mavrick's Avatar
Mavrick
Default 4 inch VS 6 inch lift...
Hey 4th gen owners, I've narrowed it down to 2 different lifts for me to purchase one is a 6inch lift and one is a 4 inch lift. I'm not sure 4 inches will give me the stance I'm looking for, so if you have a 4 or 6 inch lift could you post your before and after pictures in this thread along with tire size? On another note both lifts have a option that includes fox shocks over the standard hydraulic and another option for nitrogen for about $400 more...is it worth it?
Old Jun 4, 2019 | 07:29 AM
What size tires do you want to run??
Old Jun 4, 2019 | 02:19 PM
Mavrick's Avatar
Mavrick
I'm on 33's stock I would do 35's or 37's basically the biggest for the lift.
Old Jun 5, 2019 | 07:23 AM
The more you lift, the larger the tire you can fit. Of course, going to the larger tires is going to cause other issues as well. 35's won't be so bad, but, doing to 37's you would likely want to re-gear as well. (expensive) What gears ya got now?
