Warning light servo 4 wheel drive .
Old Aug 26, 2019 | 10:53 PM
dkjclj's Avatar
dkjclj
Default Warning light servo 4 wheel drive .
2011 ram 1500 , crew cab Laramie hemi , automatic trans, 57,700 miles . 2 and half weeks ago i had the misfire code on cyclinder #2 . I just installed 2 new champion plugs and a coil pak . All good . Yesterday the servo 4wheel drive light came on so did check engine light . Today when I moved truck in driveway they were both off. I was wondering if anyone else has had this. I bought truck new thank you
Old Aug 27, 2019 | 12:32 PM
SHO Rod's Avatar
SHO Rod
Since the Service 4WD light came on there should be a stored code, even though the light is not currently active. The easiest means of determining the likely cause would probably be to find someone with a professional grade scan tool to pull the diagnostic code for the 4WD system.
-Rod
Old Aug 27, 2019 | 12:38 PM
dkjclj's Avatar
dkjclj
-Rod
Thanks I will go to O'Reilly's and see what they say . I really appreciate your help.
Old Aug 27, 2019 | 08:52 PM
dkjclj's Avatar
dkjclj
As soon as I started to town the servo light 4 wheel drive came back on but I noticed the temp gauge was reading on cold side the whole 6 miles .pulled into o'Reilly went inside came back when he turn on key it all cleared but he got a code for a bad coolant temperature sensor. So I got one will change it tomorrow. But everything' was good pulled boat home .Again thank you
