Tpm
Old Sep 13, 2019 | 09:37 AM
brush4646's Avatar
brush4646
Default Tpm
I had a TPM go bad on the right front tire. They put a new one on and rotated the tires. When I left the garage the screen still showed the right front blank for about five miles then it showed it was working.My question is shouldn't hve showed up where the right front was rotated to?
Bob
Old Sep 13, 2019 | 08:49 PM
outlawstorm's Avatar
outlawstorm
From what I know,, the TPMs reset themselves,,, so when you rotate your tires,, the TPMS monitors will reset to the tire location,,, which is nice as you dont need to get them programmed everytime you rotate the tire or have to replace one
Old Sep 14, 2019 | 09:47 AM
primem's Avatar
primem
it took 5 miles to update to the new position.
Old Sep 14, 2019 | 03:14 PM
daktwos's Avatar
daktwos
I recently replaced two original oem sensors at home and rotated the tires and everything initialized to the SKREEM(Sentry Keyless Remote Entry Module) module within 1/2 mile or so.You have to go at a steady speed above 15mph.
More info about how it works here:https://www.moderntiredealer.com/art...er-ram-pickups
Old Nov 20, 2019 | 11:08 PM
WIMPY 1's Avatar
WIMPY 1
Default Tpms
Have a 2015 ram 2500 with 35x12.50x20 and tpms light steady flash on dash
any cures for this
Old Nov 21, 2019 | 12:24 AM
primem's Avatar
primem
if the tpm light is flashing...its not low pressure but rather a fault in the system...most likely a bad sensor. codes will be set in the rf hub. get the code read. scan tool that can access chassis codes required.
Old Nov 21, 2019 | 12:50 AM
WIMPY 1's Avatar
WIMPY 1
Default Thanks
New to this site not sure how this works
Thanks for ur response I'll see about replacing them
