Locked out
Old Sep 24, 2019 | 11:39 AM
Tangle Eye's Avatar
Tangle Eye
Default Locked out
My door lock gets stuck in my 2011 ram 1500 and I can not unlock it. Even the key does not work from outside. Can any one help me?
Old Sep 24, 2019 | 12:08 PM
Tried spraying some lubricant into the key hole? Do you have an FOB and does that work? Can you unlock from the inside ?
Old Sep 24, 2019 | 12:52 PM
Tangle Eye's Avatar
Tangle Eye
I do have a fob and no it does not work on the driver's door. It does work on the other three. And no I can not pull the lock up from the inside either.
Old Sep 24, 2019 | 02:29 PM
ol' grouch's Avatar
ol' grouch
Sounds like your actuator has failed. Either that or the linkage.
Old Sep 24, 2019 | 02:34 PM
You will need to pull the door panel off and inspect the locking mechanism.
