no heat in cabin.
Old Dec 23, 2019 | 03:13 PM
blackfire92's Avatar
blackfire92
Default no heat in cabin.
2014 dodge ram 2500 Bighorn 6.4L hemi 64k miles
So.... i brought the truck to a dealer to be serviced since the repairs were going to be covered. it been at the dealership being serviced for 4 weeks. Heres what i know and if im missing anything or can pass anything to the dealership please let me know. After the dealer works on the vehicle for an extended amount of time on first startup there is heat. after the 2nd or 3rd start no heat and so on.
The truck normally operates between 180-195 degrees on the coolant gauge. ambient temp currently is 10 - 40 degrees F.
heater core hoses verified hot on both lines in and out., replaced control module twice, replaced 3 actuators ( foot, defrost, and blend air), replaced pinched wire harness for actuators (found after removing dash) verified doors working correctly. Its been reprogrammed. the main controller for the hvac was swapped with a new one. verified no air pockets in line and coolant level is at the proper amount. verified heater control valve is in working condition. The re-circulation door is not broke and functioning, blower motor is working and vents are directing air properly but just cold air. no coolant leaks.
After replacing a module and reprogramming and or whatever the dealership does the heat works for the first start... after that its dead again. its been a month and the dealership said its got a mechanic a programmer and an electrical technician working on it... still stumped please help.
Old Dec 23, 2019 | 05:42 PM
Does it smoke the module the first time you use it? If so, look for a short in the wiring somewhere, or a bad ground.
Old Dec 23, 2019 | 07:25 PM
blackfire92
after replacing the pinched wire found on the blend air actuator the new module has not shorted out. I called and verified with service, the grounds are working properly after there tech checked them.
Old Dec 23, 2019 | 08:07 PM
Are the modules still failing? Or is it working properly now?
Old Dec 24, 2019 | 08:18 AM
DodgeCares's Avatar
DodgeCares
Hi blackfire92,
We sincerely regret to hear of the trouble you have had to experience. Please know that if you are in need of any additional support while addressing this with your dealer, our team is just a PM away.
Rob
DodgeCares
Old Dec 24, 2019 | 09:53 AM
blackfire92
modules are working... directing air flow where its requested. no heat though.
Old Dec 25, 2019 | 12:56 PM
tomdel45's Avatar
tomdel45
1997 dodge ram puck up no heat in cabin temp goes over 200 but does not over heat. blower fan works fine. what would no heat . ?
Old Nov 13, 2022 | 07:19 AM
KJSJJJ's Avatar
KJSJJJ
Default No heat in cab
Hello, I have the same problem with my 15 ram 3500 hemi. What did u finally do to solve problem ji
Old Jan 23, 2023 | 12:06 AM
bigbuck71's Avatar
bigbuck71
Arrow sounds slike my issue
Hey,wish I could help,but I am having the exact same issue , cold air only blowing on the floor,and my heat is all the way up....their are youtube videos to help recalibrate the blend door acuators, but mine is a touch screen and a separate button for the recirculation( its different than having it on the manual dial"low to high dial"....I think my computer is not sending the correct signal for heat at the control module? Do you know if its expensive to have it reprogrammed? TIA....btw, I have a 2014 1500, 5.7 hemi bighorn
