Voltage regulator bypass
Old Feb 1, 2020 | 06:47 AM
  #21
B4dR4M's Avatar
B4dR4M
Originally Posted by primem
if you are trying to load test the battery...disable the fuel pump and crank it over till it stalls. then crank it over for 7seconds..if the battery stays above 9.6 volts during the load at the 7second mark; its good.
a battery with a bad cell can cause the charging system to overcharge.
I have not tried that. It’s been fine since December and just recently it started again and not keeping a consistent voltage. It also started making my dash go haywire as well as the stabilizer light comes up when the voltage is too high, as well as the cruise control not working
