2009 Speed Control
Old Jan 2, 2020 | 07:21 PM
jayhock's Avatar
jayhock
Default 2009 Speed Control
Apologies if this has been stated, but I couldn’t find an exact answer anywhere.
Have a 2009 Ram 1500 crew cab with a 4.7. I’ve read quite a few threads on cruise, but here’s a straight forward question: if the cruise light never comes on (not at startup or when attempting to set), what are the most common issues? I purchased this truck a couple of months ago and have never had working cruise during this time. Before taking it to a dealer Monday I’d like to make one last ditch attempt to figure it out first.
Old Jan 2, 2020 | 08:32 PM
Press and hold the trip/reset button, turn the ignition "on", (don't start it.) that *should* initiate a cluster test, all the bulbs should lite up, all the gauges should do a full sweep. See if the cruise light ever comes on....
Old Jan 3, 2020 | 09:38 AM
jayhock's Avatar
jayhock
Thanks for the tidbit, so the cruise light doesn’t come on with this test either. Could a bad switch cause this or am I looking at another possibility?
From my research, I’d think that a vacuum or break pedal issue would still allow the light to be on, but not allow the cruise to engage. So we’re more electrical/power based. It appears there’s no dedicated fuse, and I wouldn’t know where to begin to look to insure cruise is even connected under the hood.
thoughts/suggestions?
Old Jan 3, 2020 | 09:41 AM
If the light doesn't come on during the cluster test, either the bulb is burnt out, or something else is going on..... Not sure just what cruise-related data is available from the PCM..... would likely need a fairly high-zoot scanner to read it anyway.
Old Jan 3, 2020 | 10:14 AM
jayhock's Avatar
jayhock
Cruise would still function if only the bulb was burnt out though wouldn’t it?
Old Jan 3, 2020 | 11:27 AM
I would think so......... But hey, it's FCA, ya just never know.
That's why plugging in with a good scanner may be helpful. You *should* be able to see what the PCM thinks is going on, when you press various buttons. Service manual would come in REAL handy here......
Old Jan 6, 2020 | 09:13 PM
jayhock's Avatar
jayhock
Quick follow up for anyone searching this issue. I took it to the dealer this morning, it was the switch, which is a common issue with this generation of Ram, apparently. The cluster test, oddly enough, wasn't useful as the cruise light/indicator is on the digital system panel and not on the dash panel. Appreciate the responses "HeyYou"!
