Tail light fuses
Old Feb 4, 2020 | 04:40 PM
B4dR4M's Avatar
B4dR4M
Default Tail light fuses
So I went through my fuses on Sunday while my truck was off since I’m currently dealing with an electrical issue, I’ve came across 2 fuses (m17 and m18) showing to have 3.5 volts. Now the question is, what’s the voltage that should be showing on those fuses? I’ve tried to find it with research but no luck. This is on a 2012 Dodge Ram 1500 4.7L
Old Feb 4, 2020 | 06:33 PM
SHO Rod's Avatar
SHO Rod
If you remove the fuses and check both sides of each fuse with a meter, what do you read?
-Rod
