Help don't know where to look
Old Mar 8, 2020 | 01:56 PM
Tadley78's Avatar
Tadley78
Default Help don't know where to look
Hello new member to the site from a small town in texas. Self employed plumber, looking for some help with my 2013 Ram 1500 did a MDS delete cam and lifter swap after the #6 cylinder misfire code keep popping up followed instructions to a tee truck will not start and idel it start if you hold accelerator down half way but runs very ruff
Old Mar 8, 2020 | 05:17 PM
Welcome to DF!
Are you getting any codes?
Moving this to fourth gen ram section for ya.
Old Mar 9, 2020 | 04:54 AM
Tadley78's Avatar
Tadley78
No codes at the moment9
Old Mar 9, 2020 | 12:22 PM
See which cylinders aren't firing.
Old Mar 10, 2020 | 02:29 PM
Pedro Dog's Avatar
Pedro Dog
I had a similar experience before on another vehicle (not a ram). Turned out that the cam the shop gave me was for a different model. Make sure you got the right cam P/N for the truck and not for the other applications of the 5.7. I had to tear the car apart to find out.
Old Mar 11, 2020 | 02:38 PM
d0dg3's Avatar
d0dg3
Default The first thing to try is to turn off the MDS override function.
If that fixes the problem you will need a tuner to turn off the MDS permanently. That or check for a vacuum leak on the intake some where.
