2012 5.7 tick
Old Apr 11, 2020 | 04:58 PM
06Ramin's Avatar
06Ramin
Default 2012 5.7 tick
I have a 2012 1500 with the 5.7. It has developed a tick on the drivers side. I am having a hard time determining if it is an exhaust leak at the manifold or a lifter tick.
I already replaced the manifold, manifold bolts and gasket.
The tick can always be heard but seems to be quieter when the truck is in gear.
I attached a video of the noise. Any tips/advice would be greatly appreciated.
Old Apr 11, 2020 | 05:46 PM
TrueDogman's Avatar
TrueDogman
Exhaust manifold leaks are quite often more noticeable when cold and diminish during warm up to full operating temp.
Old Apr 13, 2020 | 02:27 PM
dokken08's Avatar
dokken08
My 2012 is at the mechanic as we type getting the passenger manifold replaced for the tick. As stated above it went away after the truck warmed up.
$500 repair, including parts.
Old Apr 14, 2020 | 03:23 PM
djacobson's Avatar
djacobson
You can use the output of a shop vac and pressurize the exhaust system from the tail pipe. Soap bubbles on the manifold and you can find your leak.
