Passenger Rear end impact
Old May 1, 2020 | 02:25 PM
Dar93's Avatar
Dar93
Default Passenger Rear end impact
So my rear end was impacted on the passeneger side. Did not make contact with the box. Made straight contact with rear passenger rim/tire causing hub cap to break and a wobble to happen. Of coarse for the wobble i inspected my self , which was bent from the impact. So i replaced the axle. I also got the tire and rim checked and they were A Ok. Slapped everything together , got a 4 point wheel alignment at the dodge dealer and it passed under specs but the rear passenger was off .3 of a degree which isnt much they said. Brought it home parked it and noticed my rear passenger tire sit further in then the driver rear about 3/4 inch. I measured the 4 corners underneath an the numbers are the same. I inspected the spring saddle and track bar they look ok , but i notice when i stick my hand between the wheel an the tire of the pasenger theres less space then the driver side. Im getting a lift installed as people said its ok to do so if alignment passed and everything feels fine an drives straight , and if i do need frame measurements its still a doable job with a lift being intacted. Ive bin stumped for awhile this need some answers or suggestions yall. Thanks alot much appreciated
Old May 2, 2020 | 09:04 AM
TrueDogman's Avatar
TrueDogman
This is gonna be anyone's guess over the Internet. with everything you have said I can't imagine your truck passed a 4 wheel alignment. I'm not quite understanding how you are taking your measurements but I do recall seeing pictures you posted. I'm not sure if it's possible the box shifted on the frame? Try switching wheels from one side to the other on the rear. A good mechanic should be able to inspect and measure to see what has happened.
Old May 2, 2020 | 11:42 AM
Dar93's Avatar
Dar93
Yea the box did shift , noticed the bolts moved abit , as well as the track bar! Not sure why the dealer ship didnt fix it them selves but i will be realigning the box an track bar. It goes in for a lift kit tomorrow so they most likely will fix it when it goes for alignment again.
