Code 0520 Oil Pressure Sensor
Old Jun 16, 2020 | 09:17 AM
captjohn's Avatar
captjohn
Default Code 0520 Oil Pressure Sensor
Thanks for the add to this forum. I have a 2014 Ram 2500 HD 5.7 Hemi. Check Engine code showed 0520 which indicated oil pressure sensor. The pressure has been reading between 77- 87 psi when check engine light came on. All other temps and pressures are within operating parameters. Recently had an oil change. Is the location of this sensor under engine near oil filter, between 2 cooling lines? Or is it on top right side of engine?
Last edited by captjohn; Jun 16, 2020 at 10:37 AM. Reason: added current operating parameters
Old Jun 16, 2020 | 12:15 PM
Welcome to the forum. Moved to the 4th gen Ram section.
Old Jun 16, 2020 | 02:06 PM
TrueDogman's Avatar
TrueDogman
Near oil filter. There will also be a oil temp sensor. Make sure you work on the right one.😊
