Timing 5.7 hemi
Old Jul 18, 2020 | 03:13 PM
Dodge1936's Avatar
Dodge1936
Default Timing 5.7 hemi
I replaced the camshaft on my 2012 Ram 1500. Fired it up and it stumbles and stalls. Hard start. No codes. I presumed the timing was off. Removed the oil pump and found that the marks align with each other but, the camshaft is not perfectly at 12:00 when the crank is at 6:00. I don’t understand how it can be off. Any help?
Old Jul 18, 2020 | 04:12 PM
TrueDogman's Avatar
TrueDogman
When I did one I do recall the crank mark being about 5 oclock. I believe cam was at 12 with the mark between 2 pointers on the chain. Lots of vids out there
Old Jul 24, 2020 | 07:58 PM
the1mg59's Avatar
the1mg59
I installed a Stage 2 cam upgrade with marks at 12 and 6, crank key is at about 2. No issues. You may be off a tooth, or maybe a bad tensioner? Did your cam require a phaser limiter? Is cyl. 1 at TDC? Did your cam require custom ECU tune?
