Cam and lifter failure, need help deciding which way to go!
Old Dec 14, 2020 | 03:05 PM
trouse40's Avatar
trouse40
Default Cam and lifter failure, need help deciding which way to go!
Ok I have a 2010 ram 5.7 hemi with mds. Lifter took out the cam and need some help deciding what I need to do. Ok, if I go with a mds delete kit does it need to be tuned out? I have a handheld that can turn it off is that sufficient?
Old Dec 14, 2020 | 04:31 PM
MDS needs to be disable in programming. If your handheld can turn it off, that will likely be sufficient.
Problem is, the cam/lifter failure scattered crap all thru the engine. Only way to ensure you get it all clean out, is a complete teardown. Otherwise, you are just asking for trouble.
Old Dec 28, 2020 | 10:56 AM
Mike Holmen's Avatar
Mike Holmen
Lucky that you don't own a newer hemi, like 2016 and newer. The ECM has to be sent in to unlock, prior to any program mods. I own a 2016 and 2020 hemi ram 1500.
Texas speed has a new hemi cam line-up. Its dam pricey to fix-up these newer dodgies.
https://www.texas-speed.com/c-3440-hemi-cams.aspx
