Securely mounting cargo rail
Old Jan 8, 2021 | 02:04 PM
BigBlueEdge's Avatar
BigBlueEdge
Default Securely mounting cargo rail
Does anyone have good examples for how to securely mount a cargo rail system (like Core Uni Trax, US Cargo L Track, E strut, etc.) to the sidewall of a 4th gen Ram bed? I'd like to add a section or two of that type of rail about mid height (just over the wheel wells) on my 2017 Ram 2500 6'4" bed.
As far as I can tell you cannot get to the back of the inner bed wall to use a washer & nut behind a bolt. A nutsert seems like the only option unless someone knows of another plan. But will that be solid enough?
Thanks,
Rob
Old Jan 13, 2021 | 08:00 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i dont see why you couldnt get to it, i put a swingcase on mine and used bolts and nuts instead of the self tappers they included with the bracket . . . i would use big fender washers on the back so support the nut.
Old Jan 13, 2021 | 12:39 PM
BigBlueEdge
How did you get to inner and outer walls of the bed side? Did you remove the inner fender liner?
