2014 Ram Mega 3500 cummins wipers on all the time, TIPM?
Old Jun 10, 2021 | 12:13 PM
bart0510's Avatar
bart0510
Default 2014 Ram Mega 3500 cummins wipers on all the time, TIPM?
Hello all, I did a search but no luck finding anything.
My wipers are on one speed all the time unless you pull fuse. I have no control with multi switch. I have rigged up a toggle switch so at least I can operate from inside the truck.
I pulled apart the switch to see if any pins out of alignment and they look good. The other functions work in this switch.
It was looking like possibly the TIPM was bad but after speaking with a rebulder of the TIPM the state there only fix for this yearTIPM is a fuel pump issue and suggested wiring issue.
WonderiWondering one else has had this issue and what the possible fix may be.
Thanks for any input.
