Back to life
Old Sep 1, 2021 | 10:03 PM
Lcky1998's Avatar
Lcky1998
Default Back to life
Soooo I have a 2011 ram 2500 5.7 hemi. Been struggling on random/multiple mysterious misfires. This last monday the shop hadn't figured it out because it wasnt misfiring. I took it out and drove it hard for about 15 min. and the misfires started back up. They plugged the truck in before I shut it off and it read that cylinder 6-7-8 were dead, 4-5 were misfiring and 2-3 were fine. It sat for 2 days and it is Wednesday and I picked it up and it ran fine amd drove fine for the 15 min. ride home. So what would cause such a rough and ****ty running motor and then after it sits a xouple days it goes away and runs fine?
Old Sep 2, 2021 | 08:17 AM
Something gets hot, and fails. Can you do data logging?
Old Sep 2, 2021 | 10:04 PM
Lcky1998's Avatar
Lcky1998
Not sure what that intails
Old Sep 2, 2021 | 10:26 PM
Pedro Dog's Avatar
Pedro Dog
The common link here is the PCM. The computer commands the coil packs to fire as needed. If you got a loose connector at the PCM that could explain it. I would disconnect the connector and inspect the pins for corrosion.
