Please help. Door stuck closed & air suspension issues
Old Sep 5, 2021 | 01:04 AM
Thibs's Avatar
Thibs
Default Please help. Door stuck closed & air suspension issues
2013 1500 Laramie quad cab Passengers side rear door stuck closed. I’ve tried just about everything I know of from pulling seats out to access and remove door panel. Tried to reach inside door and manually open latch with no progress. Even had the rod fall off. Done this several times and very time consuming. I’ve read multiple threads on issue and nothing works. Frustrating enough to set fire to it. Lol. O and I’m having issues with the air suspension not working properly. The rear is riding all the way up (offroad 2 while the front is normal ). It will not adjust itself or manually. If anyone out there could guide me in a direction with results it would be greatly appreciated.
