2012 Ram 1500 SLT 5.7 Cruise control not working
Old Feb 25, 2022 | 08:25 PM
Bax's Avatar
Bax
Question 2012 Ram 1500 SLT 5.7 Cruise control not working
Symptom:
When the truck is first started, the CC can be turned on as indicated by the dash icon.
When the truck moves more than a few feet, the CC dash icon goes off and the CC switch is non-responsive until the truck is restarted.
CEL is NOT on.
Stored codes:
P0579 - Speed Control Switch 1 Performance.
P0581 - Speed Control Switch 1 Circuit High.
P0513 - Invalid Skim Key.
P0591 - Speed Control Switch 2 Performance.
Google search not that helpful.
Any thoughts?
Old Feb 26, 2022 | 08:48 AM
If it works the same way it does on the older trucks, the switches on the steering wheel just modify a signal from the PCM, to clue the PCM in to what you want. In your case, I would suspect bad switches, or the clockspring going out.
