My turn for valvetrain failure?
Old Mar 26, 2022 | 09:44 AM
Swapping an injector is gonna be easier than pulling the heads.
Measuring valve travel is likely a good idea.
Old Mar 27, 2022 | 07:11 PM
magnethead's Avatar
magnethead
Working 7 day weeks, I don't have time to do much more than throw a coil at it - i might get an injector on it this week. Otherwise it's heading to have the cam and lifters replaced.
My first open weekend is May 28; then June 18 and beyond. Until then, I'm working 7-day weeks or at a racetrack.
Old Mar 27, 2022 | 09:49 PM
magnethead's Avatar
magnethead
Just changed the #3 injector at the lovely hour of 7PM.
Same thing.
Replaced Spark
Replaced Fuel
All we can assume is that the air's not there.
Old Mar 27, 2022 | 11:05 PM
magnethead's Avatar
magnethead
Just ordered the Mark82 camkit and HPT tuning from www.frptuning.com. joys.
Old Apr 5, 2022 | 12:24 AM
magnethead's Avatar
magnethead
Survey says....
Oh, and bonus points to me. 6 other lobes were already past the hardened finish and starting to come apart.
https://photos.app.goo.gl/NJppHjnKNES7epxG6
https://photos.app.goo.gl/seahFGSg3rboQqvk7
https://photos.app.goo.gl/CkEhCXdRNy3a5TDx7
https://photos.app.goo.gl/XZhhhngVWEPkop899
Old Apr 5, 2022 | 09:42 AM
Wow, that's pretty trashed.
Were the rollers seized up? Or are they just poorly made cams??
Old Apr 6, 2022 | 02:51 AM
magnethead's Avatar
magnethead
only the one roller was seized. All others were free. But 6 other lobes were past the hardened finish - 2 had pitting/missing chunks, a third had a lip you could feel.
This issue only applies to the Eagle block, 09 to 14. No exact cause known - not sure the differences between 04-08 block and 09-14 block.
The cam is the highest point in the block - the lifters sit nearly horizontal. The cylinder head return ports are below the lifters and cam.
This means that there is no oiling to the lobes and rollers. The excess off the lifter bodies goes straight down, the excess off the cam bearings goes straight down, and cylinder head return goes underneath.
Result: Splash-oiling only for the important contacting parts of the valvetrain.
Old Apr 6, 2022 | 08:40 AM
That seems like a major design oversight......
Old Apr 7, 2022 | 12:38 AM
magnethead's Avatar
magnethead
This isn't my block, this is another hemi he has on the engine stand.
https://photos.app.goo.gl/5i5ZuY7W4cwTa6hg7
https://photos.app.goo.gl/ePrZRqMfEvoX717b9
https://photos.app.goo.gl/FGstJmaWbbFwngHK7
Old Apr 7, 2022 | 09:30 AM
So how do the cam lobes get oil?? Doesn't look like anything is going to simply run down on to them, and the bleedout from the cam bearings ain't gonna help either. But, since I have seen some of these with close to 300K on them..... gotta be getting it from somewhere.....
