Wobble in rear
Old Apr 15, 2022 | 10:16 AM
Jboyer2701's Avatar
Jboyer2701
Default Wobble in rear
So I have a 2017 ram 1500 with a 6” lift and 24x14 wheels on 35s, ever since the lift was put on I’ve had a wobble around 50 mph. Now I had the wheels rebalance and my alignment checked also had lift check out and they said everything was good, has anyone had similar issues?
Old Apr 15, 2022 | 10:24 AM
Does the wobble go away if you go faster, or slower?
With those monster wheels, is there a shop around you that does "on the car" wheel balancing?
Old Apr 15, 2022 | 10:36 AM
Jboyer2701's Avatar
Jboyer2701
It does seem to go away around 60mph
Old Apr 15, 2022 | 08:24 PM
That is quite likely a tire balance problem.... or, some variety of tire problem. Try rotating the tires, see if anything changes.
