No start, no PRND on the dash
Hello,
I’ve just replaced my 5.7 hemi in the 2011 1500 with a used 5.7 from a 2014 1500. Once I turned the key. Almost all warning lights are on, no lights on the PRND at all.
Used the manual shifter release and cycled through all direction. Still will not select a position on the dash
Jumped the starter relay and got engine to crank no problem but can not get it to crank or start on the key.
I have cleaned all the ground connections.
My code reader will not connect..
any suggestions?
any suggestions?
there were changes to the electronics in 2013, I believe. If what you put in was stripped of all electronics and used all of the original stuff then you probably have some sort of connection issue. No USB is the first thing you need to resolve.
Hello,
any suggestions?
any suggestions?
Hi mattfox, this is probably a long shot cuz this was posted in 2022, just wondering if you fixed the problem? And what the out come was? i have the exact same issue.
