4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I bought a cheap kit from a seller called cn_biker on ebay. I think they had photocopied instructions from ijdmtoy and thrown them in the box with a different light bar. Basically I wound up re-working everything on the bracketry and should have just started from scratch on the brackets. Regardless, it works now. The relay is triggered with fogs. A few highlights, but basically if you don't have some fabrication capability, good luck Basically started wirh this I think the slots were intended to fit the bumper bolts but they were .400" wide and the bumper bolts are M12 (~.470"). Opening up with a 1/2" em here I wound up wanting the light higher than the brackets would allow so I actually flattened the bend in my arbor press then re-bent in a different location in my finger brake (not shown) I finally wound up with this Frankenstein thing here. I added angle because the bracket was too flimsy. All's well that ends well.....?
Nice fab work. However, if other drivers are routinely flashing their brights at you b/c they’re blinded by your light bar, don’t take it personally and consider re-aiming it or getting a better one with a more focused beam. Just letting you know that the glare isn’t appreciated.
