2014 Ram 4x4 Laramie
Old Jun 16, 2023 | 05:46 PM
Morty760's Avatar
Morty760
Default 2014 Ram 4x4 Laramie Air Ride
Well hello everyone, it's been a while.
2014 Laramie with air ride problem.This truck is using nitrogen in this system, not regular air. This truck doesnt stay at ride hight when parked and turned off, sometimes. Start the truck up and the truck raises to normal height. When coming out of aero, the truck rear bottoms out while driving. Have to pull over and park and it'll raise to normal height. SO, basicallly if we drive the truck under 60mph, where it doesnt hit aero, we're fine. Took it to a dealer to have them check it out and they said that the air pump was broken and theres a line leaking from both ends that hooks up to the pump.
Problem with their diagnosis is that the pump does work and the suspension does go up and down. If it had this "leak" for at least 6 months or so, wouldn't it run out of nitrogen? I' thinking a sticking or stuck valve/switch.
Any help on this would be greatly appreciated.
Old Jun 20, 2023 | 10:53 AM
William Scott's Avatar
William Scott
It's unlikely that the nitrogen would completely run out over time because it is a sealed system.
