Braking in 4wd grinding noise
Old Jul 30, 2023 | 07:07 PM
robertmcguire871207's Avatar
robertmcguire871207
Default Braking in 4wd grinding noise
2014 Ram 1500 There is no noise when braking , but when I put in in 4wd auto there is no noise until it down shifts from 2 to 1 gear , I checked the boots on the cv axles none ripped but seems like the driver side has more play in it when I push it up and down . Please help
Last edited by jkeaton; Jul 31, 2023 at 07:36 AM. Reason: Corrected spelling of "brake".
Old Jul 31, 2023 | 07:37 AM
Describe the noise. Where is the noise coming from?
Old Jul 31, 2023 | 07:53 AM
robertmcguire871207
It’s more of a grinding noise from the front somewhere but I don’t thinks it’s from transfer case or front diff because it don’t do it all the time only when the truck is braking from like 2 to first gear
Old Jul 31, 2023 | 08:41 AM
The check the brakes if it only grinds when braking.
Old Jul 31, 2023 | 09:04 AM
robertmcguire871207
I don’t think it’s the brakes because it don’t do it in 2wheel drive only in 4 wheel drive
Old Jul 31, 2023 | 09:46 AM
Gotta start somewhere.
Old Jul 31, 2023 | 12:45 PM
robertmcguire871207
Checked calipers and pad’s everything looks fine
Old Jul 31, 2023 | 01:08 PM
Try turning and braking in 4wd. (NOT on a high traction surface, thankyouverymuch) see if the noise is different in one direction.
Old Jul 31, 2023 | 03:19 PM
robertmcguire871207
Ok thank you I will try that
Old Jul 31, 2023 | 05:19 PM
robertmcguire871207
Sounds more like a bearing grinding . Is there bearings in the front differential?
