Poly Trans Mount?
Old Aug 12, 2023 | 10:41 PM
magnethead's Avatar
magnethead
Default Poly Trans Mount?
Is there a poly trans mount available?
My 2011 5.7 is shakingshimmying/shuddering under braking (190,000 miles). We ran it on jackstands much to TCS's/ABS's chagrin and it still does it. We can't tell where it's coming from but the back of the trans is moving around alot. The mount is still in 1 piece but is a cheap part to replace.... I'd like to put a poly one in if I can but all I can seem to find is rubber?
O'Reilly doesn't stock one at all for RWD, only 4WD. RockAuto has a few different options. Advance shows the Anchor 3377 for $110 while rockauto has it for $45.
Old Aug 13, 2023 | 08:54 AM
It looks like it's the same mount 2 or 4 wheel drive..... not sure I trust that info though. But, yer right. I can't find anything for the newer trucks in poly.
Old Aug 14, 2023 | 11:19 PM
magnethead's Avatar
magnethead
I ordered the Anchor kit off RockAuto. For $150 it includes both motor mounts and the transmission mount.
Old Aug 16, 2023 | 03:16 AM
William Scott's Avatar
William Scott
did you try to search on ebay ?
