Fuel Pump Stays on after Key is off
Old Dec 29, 2023 | 02:08 PM
ChiRam2500's Avatar
ChiRam2500
Default Fuel Pump Stays on after Key is off
So had the fuel pump changed. Once I filled up tank it stayed on after I turned key off. I changed the fuse relay for the pump. Didn’t do it again till I refilled up again. I pulled use out and it turned off put back in and it’s not doing it again. The fuse is good so I don’t know what it could be. Fuel pump is Mopar.
2012 Dodge Ram 2500 5.7 Hemi
Old Dec 29, 2023 | 02:58 PM
Probably a failing/sticking relay. Unfortunately, they are not easily replaceable. I think there is a kit available for an external relay though.
Old Dec 29, 2023 | 03:10 PM
ChiRam2500's Avatar
ChiRam2500
where is that located? Inside tank? @HeyYou
Old Dec 29, 2023 | 03:14 PM
Relay is in the TIPM.... Under the hood.
Kit to fix it. Kit to fix it.
Old Dec 30, 2023 | 12:28 AM
ChiRam2500's Avatar
ChiRam2500
@HeyYou link didn’t work
Old Dec 30, 2023 | 09:36 AM
Try this one. This looks interesting. No experience with it though.....
