Need Help!!! Electrical problems
Old Mar 6, 2024 | 05:04 PM
Chadillac23's Avatar
Chadillac23
Default Need Help!!! Electrical problems
Hi
i have a 2012 ram 1500 and about 2 months ago my Tire pressure light came on so I checked the tire pressure on the dash and front right tire reads - -. And then a day or so later my Trailer light brake disconnect came on and CF on trailer brake flashes and service 4wd and traction control all come on at same time.
also randomly my Electronic throttle control comes on and truck Boggs down and then goes off. Those lights are all randomly coming on. Tire pressure light stays on.
i took to shop and they said it was the WIN. So I had them replace for $1000 and all my lights came back on in 20mins of driving. Any ideas?
Old Mar 6, 2024 | 05:36 PM
Go back to the place that charged you 1000 dollars, and didn't fix it.
Old Mar 6, 2024 | 11:49 PM
SHO Rod's Avatar
SHO Rod
In addition to returning to the shop that didn't fix anything, how old is the battery in the truck? Considering these issues are all electrical in nature, I'd be looking at something common to all. With many modern vehicles it seems that 3 years is kind of the norm for when batteries start to fail. If your battery is 3 years old or older you might consider it time to replace and it just might also fix these strange issues.
-Rod
Old Mar 7, 2024 | 07:33 AM
Take it back to the shop.......
Old Mar 7, 2024 | 10:24 AM
Chadillac23
-Rod
looks like it’s my brake switch stuck on! Changing it out today
Old Mar 7, 2024 | 01:25 PM
SHO Rod's Avatar
SHO Rod
That would be great if the fix is that simple. But I don't quite understand the correlation between a stuck brake light switch and most of the symptoms listed in the original post.
-Rod
Old Mar 7, 2024 | 02:42 PM
Chadillac23
-Rod
After I posted my original post I had a check engine light come on and it read bad brake switch, so I checked brakes and my brake lights were stuck on, so I just changed the switch but the other lights are still coming on intermittently
