Windows not working
Old May 29, 2024 | 08:22 PM
11dodge2500's Avatar
11dodge2500
Default Windows not working
i just got my 2011 dodge 2500 and the passenger window only works from the driver switch not the passenger. both rear windows don’t roll down from any switch. Any ideas? i’ve replaced the drivers door switch and checked all the fuses.
Old May 30, 2024 | 06:52 AM
See if you are getting power to the window motors from the local switch. My guess would be "no". Need to figure out why.
Old May 30, 2024 | 02:20 PM
SHO Rod's Avatar
SHO Rod
For the passenger window, have you confirmed the window lock is not on? When the window lock is engaged, the master switch (driver's switch) is the only one that will work the windows. So that wouldn't explain why the rear windows won't work from the master switch, but might at least get the passenger window working.
For the rears, like HeyYou mentioned, you're going to need to start checking for power and working either backwards or forwards until you find the issue. Do you have access to the wiring diagrams for the power windows? Or AlfaOBD or a high end scan tool that may allow you to try to control the windows from the tool and bypass the various mechanical window switches?
-Rod
