09 ram 1500 MDS issues
Old Nov 17, 2024 | 12:33 PM
Tazzman52304's Avatar
Tazzman52304
Default 09 ram 1500 MDS issues
I have a 2009 laramie 4x4. I just put a remanufactured 5.7 hemi in it. When the shop gave it back after installing the new motor the check engine light popped on for a MDS solenoid. The mechanics ended up putting in new MDS solenoids. The truck ran fine for about 60miles and then check engine light popped up again for the same problem. And now I can't remotely start it either. Has anyone one ever come across this and is there something that can be causing this. I have also put a new 800cca battery in thinking maybe a voltage problem but still same thing. So please help what else should I do. Maybe a new MDS wiring harness?
Old Nov 17, 2024 | 12:37 PM
09 is a fourth gen truck. Moving this to fourth gen section for ya.
Welcome to DF!
Old Nov 17, 2024 | 12:52 PM
Tazzman52304
Thank you.
Old Nov 19, 2024 | 09:53 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
I'd check the MDS harness from each solenoid to the main harness/PCM. In fact I would check ANY wiring that would have been disturbed during the process.
Old Nov 24, 2024 | 11:10 PM
Tazzman52304
Would you know of a place that would sell a replacement wiring harness. Dodge has discontinued it.
